Wow...opened up fuel pump today
Has thanked: 85 times
Been thanked: 97 times
Post by ShowMePatrol »
Today as I stared at the original pump, I wondered why the PO cut the lines and installed a cheap non-functioning electric pump. The original pump looked good. Well, curiosity got the best of me so I removed the pump and opened it up. I spent about an hour cleaning the mess from inside the pump and 45 degree pipe. I will put it back together in the morning and see if it works. I think it may be salvageable.
1150
1152
1153
1154
1151
Has thanked: 104 times
Been thanked: 175 times
Re: Wow...opened up fuel pump today
Post by Swerve »
nasty, hope it all works
Has thanked: 54 times
Been thanked: 17 times
Post by norville »
ShowMePatrol wrote:Today as I stared at the original pump, I wondered why the PO cut the lines and installed a cheap non-functioning electric pump. The original pump looked good. Well, curiosity got the best of me so I removed the pump and opened it up. I spent about an hour cleaning the mess from inside the pump and 45 degree pipe. I will put it back together in the morning and see if it works. I think it may be salvageable.
1150
1152
1153
1154
1151
yummy, keep us posted, I may be doing this soon..
(insert clever saying here)
Has thanked: 7740 times
Yikes! :shock: :o No wonder the carb was replaced. :roll:
Did you take apart the bottom section to inspect the diaphragm? That is another possible failure point.
Has thanked: 310 times
Been thanked: 176 times
Post by bosque »
This is a nice photo journal of this process. Baggies, sharpies and photos are the best reminders. Keep on it! :clap:
Yes, took it completely apart. It was a mess. I reassembled this morning and bench tested.....success!!!! Unfortunately, the hard pipe from the pump to the carb is clogged also........uggggg. I imagine the pipe from the pump to the tank is clogged also, not to mention the tank itself. I plan to drop the tank next weekend and send to a shop for thorough cleaning.
I've always used baggies/marker to keep things organized. Also take plenty of before and after pics with the cell phone just in case.......:)
1156
1155
1157
1159
1158
1159
Awesome!!! :clap: :clap: :clap: I'll bet that many fuel pumps that have been bypassed could be rescued this way, too.
Good luck with the metal fuel lines. A nice long, stiff wire and some compressed air is a good start. Even after all of that, keep plenty of extra fuel filters on hand. ;)
Im going to see how much a new line would be. Do you happen to know the line size from the engine area to the tank?
Has thanked: 39 times
Been thanked: 75 times
Post by MadTripper »
ShowMePatrol wrote:Im going to see how much a new line would be. Do you happen to know the line size from the engine area to the tank?
I bet mig wire would be handy...nearly free..and stiff enough to push through.
Tripper
I don't know the size off-hand. FYI - if you haven't already figured it out, everything on the Patrol is SAE, not metric. :)
