clutch question
Posted: Wed Jan 12, 2022 7:42 pm
by CWallace
Gday folks,
Will a clutch that suits the p40 engine fit the nissan 4.0p?
Re: clutch question
Posted: Wed Jan 12, 2022 10:11 pm
I won’t fit. The P engine has thicker splines at the gearbox. The P40 has thinner splines.
There’s a Ford 11” clutch from 1942 to 1965 with 1-3/8”x10 spline hub from some supliers in the USA.
For example:
https://www.vanpeltsalesstore.com/81T-7 ... p_778.html
At Rockauto use: FORD > 1958 > F-100 > 4.4L 272cid V8 > Transmission-Manual
M-PACT 280607 11" X 1-3/8" X 10T
Re: clutch question
Posted: Thu Jan 13, 2022 4:02 am
by CWallace
Thanks esteban
So what is the best option for a complete new clutch? Again I'm struggling to find the right one.
Re: clutch question
Posted: Thu Jan 13, 2022 6:53 pm
Are you able to source the Ford clutch disk over there?
I purchase one last year as a spare after reading the following post. I have an old disk that I can compare for you this weekend, and also look at how it fits on the clutch plate.
viewtopic.php?f=24&t=6092&p=49308&hilit ... tch#p49308
Sourcing the pressure plate can be difficult. So the regular route of replacing everything might not work. But if your pressure plate is in decent shape I will just keep it untouched.
Re: clutch question
Posted: Fri Jan 14, 2022 10:14 am
by faux40
I had my clutch and cover rebuilt at a local shop here in Northern California... but that probably doesn't help much being a million miles away and all! Look around for a shop that re-lines big truck brakes... they probably can do the clutch and cover too.
Good luck!
Re: clutch question
Posted: Sat Jan 15, 2022 7:53 pm
by Peter60
There are plenty of G60 clutches on ebay.com.au.
Just make sure they are for a G60.
Re: clutch question
Posted: Mon Jan 17, 2022 4:12 am
by CWallace
Thanks guys. I'll have a dig around and see what I can come up with
