Page 1 of 2
P-40 distributor adaptation
Posted: Thu Sep 23, 2021 7:13 pm
by Zoltar58
I know this has been addressed elsewhere but I can't find what I need to know. I waterproof distributor seems to be shot ironically Rusty. I bought a P-40 distributor but the end of the shaft is too big to get through the distributor stand or mount. Wondering if anybody has dealt with this and fixed it or did I just buy the wrong distributor. Here's some photos thanks so much
Re: P-40 distributor adaptation
Posted: Fri Sep 24, 2021 7:29 am
by desertrat
Is your new dizy 1.063"/27mm diameter?
Not seeing any pictures.
Posted: Fri Sep 24, 2021 8:33 am
by Zoltar58
It won't let me add pictures it's saying the image must be at least 0 pixels High blah blah blah
Posted: Fri Sep 24, 2021 8:34 am
by Zoltar58
If you're willing to send me an email or phone number I can get them to you that way thanks for any help
Posted: Fri Sep 24, 2021 4:37 pm
by jwgreen
Posted: Fri Sep 24, 2021 4:44 pm
by Zoltar58
Thats the one that i b ought. the bottom part does not fit through the distributor stand.Now that I just wrote that I wonder if i can remove the bottom put it through the housing and put it back together?
Posted: Fri Sep 24, 2021 5:20 pm
by jwgreen
Hmmm.....I know some peeps on here have found a direct forklift replacement hopefully someone will chime in soon.
Posted: Fri Sep 24, 2021 5:59 pm
by desertrat
Zoltar58 wrote:Thats the one that i b ought. the bottom part does not fit through the distributor stand.Now that I just wrote that I wonder if i can remove the bottom put it through the housing and put it back together?
Are you saying the drive on the bottom of the shaft is larger in diameter than the mounting shank of the distributor body?
What's the part number on the distributor body you received new?
Resize your pictures to less than 1024 high x 1280 wide and they will post.
Posted: Fri Sep 24, 2021 8:39 pm
by Zoltar58
Posted: Fri Sep 24, 2021 8:44 pm
by Zoltar58
I don't have the number in front of me but it was the number referenced in the above post
