oils
Posted: Wed Apr 21, 2004 2:32 pm
by npca-benjji5
what type of oils should I run for rearend,steering and trans and motor.
oils
Posted: Thu Apr 22, 2004 7:43 am
by npca-polarscooter
If you are asking about oils for an early model Patrol, I would suggest 80-90w gear oil for the transmission, transfer-case, axle differentials and steering box. Synthetic oil is better, but costs a lot more. You might consider an oil additive. I've had really good luck with a product called "Pro-Long": it's a bit pricey, but it works.I use 20-50 weight oil in my Patrol's engine, along with Pro-Long additive, but any good-quality oil, either straight 30w, 10-30w, or 20-40w will work fine. The main thing with engine oil is to change it and the filter often.
oils
Posted: Fri Apr 23, 2004 7:18 pm
by npca-danetteandkeith
   Lucas oil addative is good for the engine as well as all other places. It is thick like maple syrup. You can put as much as 100% in diff. & tranny but it sure is stiff shifting in the winter. Engine can have  50% or 60%. It's about $5/qt. Or cheaper by the gallon.  Keith
