Found: Heater for Patrol
Has thanked: 174 times
Been thanked: 408 times
Post by mad4hws »
Hi everyone,
I recently purchased a 1973 Patrol which has spent most of its existence in Colombia. Heaters were apparently a luxury option there, so virtually none were imported with them. I live in Connecticut - and I can't imagine driving to work in the winter without a heater. Several days a year are below zero here There are several after market options available, but I'd really really like to keep the interior looking vintage. If anyone has a heater from a Patrol, I have a good home for it! Alternatively, if anyone has retrofitted their patrol with a non-factory, but still vintage option (such as from another model, manufacturer, etc.) from this same time period, I would be interested in learning more.
Thanks.
Don.
Re: Wanted: Heater for Patrol
Post by mad4hws »
mtnpatrol,
Jon - did you get my message? I haven't done messages on this forum before and I don't know if it went or not?
Post by mad4hws »
Hi everyone,
As I posted in my project thread, i did find a complete heater assembly on ebay. I took the core to the radiator shop and expect to get it back later this week. I have a template that I drew up over the weekend that I am going to try out on a piece of wood before I start cutting into the firewall. What I don't know about is how the heater hoses connect up with the radiator hose. Could someone share a picture? I'm sure connecting this up will be easy for the radiator shop, but having a reference point will be pretty helpful.
Thanks in advance.
Don.
Since I adapted a heater to mine, some variations with the original setup were done, so I hope somebody else chimes in and comments on my setup. Please note that the Patrol heater uses 5/8" hoses, but in mine I used 1/2" because that's the heater that I have at hand.
At the rear of the cylinder head, on the manifold size, there's a threaded plug, that also has the lifting bracket for the engine. You have to remove that plug and install there an adapter for the hose that goes to the inlet of the heater (the one where the valve is located). You can find this adapter at Autozone or other vendors.
Fitting at cylinder head
http://www.autozone.com/fittings-and-ho ... /?cmpid=PS:
The other heater hose returns to the engine bay and joins the system at the lower radiator hose. You'll see on the link, the adapter that I made for connecting the heater at this point. You can also buy the following adapter for this purpose at Napa: BK 6601559 (you'll have to make a hole in the radiator hose to fit this adapter)
Heater hose fitting for radiator hose
https://www.napaonline.com/napa/en/p/BK_6601559/
Please take a look at the following thread, where I show how I made an adapter for the heater hose with a picture, and its location:
Redneck approach to original Tee
http://www.60patrol.com/forum/viewtopic ... 23&p=11344
It's worth noticing that over the years, Nissan switched the location of the return hose to the upper radiator hose. Probably our members in Australia have some input on this.
Post by mad4hws »
Thanks Esteban. Much appreciated. I have some more shopping to do! I was supposed to hear from the radiator shop by today and didn't, so I'm guessing they've run into some issues with the heater core. All good, it looks like I'll have heat sooner rather than later.
If anyone can share a picture of their set-up, that would be great. My Patrol is a '73, so a later vintage where the connection might be more appropriate to the upper radiator hose as opposed to the lower hose.
Thanks.
Don.
Re: Found: Heater for Patrol
I was digging some photos here at the forum for clues. Maybe I was wrong regarding the location of the attachment of the return radiator hose being different for later models of Patrol after looking at a post of G60Michael of his 1979 MWB G60 - Parts Patrol
Heater Hose Tee Adapter at Lower Radiator Hose
Scroll down to the 4th picture in the series and you'll see that it is the same attachment as the USA Patrols. The routing of the hose towards the left side is due to different location of the heater for the RHD Patrols.
http://www.60patrol.com/forum/viewtopic.php?f=20&t=1753
Cylinder Head Fitting
You'll find great pictures across this thread of member Faux40, but in the following link you have what you need:
http://www.60patrol.com/forum/viewtopic ... &start=285
It will be nice to have the valve since you can shut down the heater during hot weather, so no residual heat will be in the cabin. I don't have that, and rely solely on the valve of the heater itself, and it's fine.
You can also use one of theses premade stainless steel tee's
http://www.ebay.com/itm/like/1710376060 ... noapp=true
Post by mad4hws »
jwgreen wrote:You can also use one of theses premade stainless steel tee's
Thanks Justin. I love ebay.
Been thanked: 1981 times
Mike, I have an extra lower radiator "T" hose. I also have an extra OEM heater. Let me know. No I do not know if the heater worked. It did before the BAM body shop disassembled Presdio Patrol and left it out in the rain for 6 months.
L60Boerne.
Post by mad4hws »
Hi L60Boerne,
Thanks for the offer(s). I had already ordered the radiator T off of ebay. I had previously scored a complete heater (also off of ebay) that I am fitting into the Patrol. So, I don't think I need anything currently. Just some extra time to get it all connected up. This weekend I cut the hole in the firewall and sanded all the rust off of the heater unit. I'll post pictures on the project thread soon.
