Broken Exhaust/Manifold Stud
Has thanked: 149 times
Been thanked: 310 times
Post by G60michael »
Hi Guy I am in the process of cleaning up the 66 engine and repainting it. I've completed the passengers side and now working on disassembling the drivers side.
I was working on unbolting the exhaust where it bolts to the manifold and snapped the front stud of about half way. The rear Stud undone easy and no problems. Now I got the exhaust off and Manifolds unbolted and will clean the engine up in the following days. I will need a new exhaust for rego,any way so it doesn't matter who removed it was going to snap.
So what do I do know the original manifold is in good condition except the snapped bolt, and the one of my 77 is stuffed with a Capital 'S' :lol:
I reckon take it to the exhaust shop get them to drill it out,tap a new thread and re-stud it :think:
Has thanked: 6025 times
Been thanked: 1605 times
Re: Broken Exhaust/Manifold Stud
If the exhaust manifold is out, maybe you should give it a try, specially if you can grab part of the stud with a locking plier.
Try this product: CRC/Freeze-Off super penetrant
http://www.bnr.com.au/ProductDetails.aspx?pid=188
Remember, the threads of that stud are UNC, not metric !!
Has thanked: 652 times
Been thanked: 632 times
Post by Coyote Patrol »
Mike, if you know how to use a torch. You can put some heat to the manifold around the stud while unthreading it with locking pliers. Do not heat up the stud, just the manifold around the stud. :D try the penetrating oil that Esteban recommends first! If that doesn't work then go to the heat. Good luck. :D
Has thanked: 12 times
Been thanked: 36 times
Post by sleepyzzz »
also, try loosening a little bit, then turning back opposite, and just keep working it back and forth. the heat does work, but we always cooled everything down before turning the stud or bolt to keep from gaulding the threads.
1967 SPL 1600
2013 Nissan Rogue
2001 Nissan Sentra SE R
Buy a center punch and cheap tap a die set if you can't coerce it out. You need the set anyhow and will cost the same as someone fixing this one problem. Grind it flat, center punch, drill undersized, ream out some new threads. If you dont have a drill press lay it on some plywood and hold it by stepping on it and drill straight. Good luck.
