G60 Tune Up Info and Parts
Locked
Post by npca-grant »
ELECTRICAL (NEGATIVE EARTH)FIRING ORDER                    1-5-3-6-2-4IGNITION TIMING                10°/450 rpm B.T.D.C.DISTRIBUTOR  CONTACT ARM SPRING TENSION    0.50 ~ 0.65kg  BREAKER POINT GAP             0.45 ~ 0.55 mm (0.020")  DOWEL ANGLE                   35° ~ 41° (point gap 0.5mm)SPARK PLUG  DIA. OR THREAD                14mm  REACH OF THREAD               19mm  DIA. OR HEXAGO                20.6mm  SPARK GAP                     0.7 ~ 0.8mm (0.024" ~ 0.028")D.C. GENERATOR & REGULATOR  CUT-IN VOLTAGE                14.5v AT 1600 rpm  NO LOAD VOLTAGE               15.5v AT 3000 rpm  PUSH UP VOLTAGE               9~11v AT 3000 rpm  BRUSH SPRING TENSION          0.36~0.5 kg  BRUSH HEIGHT (STD)            16mmSTARTER MOTOR  BRUSH SPRING TENSION          0.9 kg  BRUSH HEIGHT (STD)            16mm                 TYPE 1          TYPE 2          TYPE 3 -----------------------------------------------------------Distributor 1   22100-43801     22100-46500     22100-44201Distributor 2   22100-46500     22100-44205     22100-44205Points 1        22145-58000     22146-43805     22146-58000Points 2        xxxxx-xxxxx     xxxxx-xxxxx     22146-43805Vacuum Adv 1    22301-43801     22301-43805     22301-44201Vacuum Adv 2    22301-43805     22301-44205     22301-44205Condenser 1     22102-50001     22102-50001     22102-50001Condenser 2     22102-50002     22102-50002     22102-50002Dist Cap        22162-43800     22162-43800     22162-43800Rotor           22157-50001     22157-50001     22157-50001   TYPE 1: Dist Cap: has screw on caps for each plug wireVacuum Adv: Has threads for the metal vacuum adv lineNOTE: Dist Housing has TWO nipples/connectors for an air lines (not vacuum adv) in and out.   Type 2 and 3:Dist Cap: has the typical slip on plug wiresVacuum Adv: Has the typical slip on connector for rubber type of vacuum advNOTE: Dist Housing has ONE nipple/connector for an air line (not vacuum adv).   SUMMARY: None of these distributors have the typical clip on type of distributor caps, all three types have distributor caps that are screwed onto the housing via 3 screws. I thought I read or saw somewhere that someone had a distributor with a clip on type of distributor cap? Anyway, the two types of distributor caps (screw on or slip on spark plug wires) are the same size, because they have the same rotors and same part number for the o-rings. Thus you should be able to use either.   PARTS FROM NISSAN   POINTS (POINT-SET)http://www.nissanautoparts.com/detailli ... mit=Submit VACUME ADVANCE (ASSY CONTR) (Threaded Vacuum Line)http://www.nissanautoparts.com/detailli ... mit=Submit VACUME ADVANCE (ADVANCE-VA) (NON Threaded Vacuum Line)http://www.nissanautoparts.com/detailli ... mit=Submit CONDENSER(s)http://www.nissanautoparts.com/detailli ... mit=Submit DISTRIBUTOR (DISTRIBUTO)http://www.nissanautoparts.com/detailli ... mit=Submit DISTRIBUTOR CAP (CAP-DISTRI)http://www.nissanautoparts.com/detailli ... mit=Submit ROTOR (ROTOR-HEAD)http://www.nissanautoparts.com/detailli ... mit=Submit Grant
Post by npca-danetteandkeith »
Hey Grant, Is this info for the "P" engine? Your Subject line says G60 is that the same as KL60 or is this info for the newer Patrols? Don't mean to be nit picky,just wondering cause I need a new vacuum advance and was wondering if the link is the right one for the "P" engine. Thanks, Keith
Hey Danette & Keith   My bad.. I should have called this message:   Model 60 Series Patrol Tune Up Info and Parts   Where the G60, KL60, etc are all 60 Series... to make a long story short (TOO LATE) these settings are for the Old Patrol "P" engines.   Grant
Post by npca-denny »
 Grant....You are the man !  Thank you ! This makes it so easy.  Denny
Post by npca-voypwatcher »
; ; ; ; 1969 Patrol. Thanks you Grant for your service.; ;  ; ; -----Original Message-----; From: denny; [mailto:finnsfx@msn.com] ; Sent: Saturday, May 18, 2002 7:20; AM; To: Nissan Patrol Club Albuquerque; Subject: Re: G60 Tune Up Info and; Parts; ;  ; ; ; ; ; ; ; ; ; ; New; Message on Nissan; Patrol Club Albuquerque; ; ; ; ; ; ; ; ; ; ; ;  ; ; G60 Tune Up Info; and Parts; ; ; ; ; Reply; ; ; ; ; ; ;  ; ; ; Reply to Sender   Recommend; ; ; ; Message 4 in; Discussion ; ; ; ; ; ; ; ; ; ; ; ; From: denny; ; ; ; ; ;  ; ;  Grant....You are the man !  Thank you !; This makes it so easy.  Denny; ; ; ; ; ; ; ; ; ; ; View other communities in; this category. ; ; ; ;
Locked
