clutch and brakes
clutch and brakes
I need a clutch and brake master cylinder rebuild kits. My 65 runs like a top but I have no brakes of clutch that’s a bit of a problem I have looked every were but with no success does any one know were I could get this or if there no longer around were I can get whole new ones
- Been thanked: 1 time
clutch and brakes
Clutch master - http://cgi.ebay.com/ebaymotors/Nissan-P ... 0034602796 Brake master rebuild kit - http://cgi.ebay.com/ebaymotors/Nissan-P ... 8054761755 But, if you have a '65 your clutch is not hydraulic, so the master won't do you any good.
clutch and brakes
Just used this kit the other day with good results. Napa brake master kit # 387. Will not seem right ie the parts seem too small but it will work, need to save some parts from yours. The retainer clip is the main piece the one from the Napa is too small. Also the Napa kit does not come with the piston spring so if yours is weak go with npca-riverpatrol's sugestion. I got great results with the Napa kit, followed by bench bleed, then new fluid and bleeding of all the brakes, just make sure all of you wheel cylinders are good. This Napa kit was like $14 and a lot cheaper than the one on Ebay!
- Lurker
clutch and brakes
I may be able to help on the clutch and brake cylinder. I am in Boise, Id. 866-0472
