Front Brake Cylinder AC Delco 18G94 Rebuild Kits - Out of Stock
Original and compatible parts
Been thanked: 1980 times
Greetings,
From my search today. Austailia suppliers are currently out of front wheel cylindders for the G60. Furthermore, it seems AC Delco no longer manufacturers the 18G94 repair kit listed in the Parts List herein.
I usulay keep some in stock but Ive used them all.
If anyone has any new or guartanteed good front wheel cylinders please contact me.
or
If you are aware of a compartable repair kit, please send me that kit information.
Rolling and Patrolling,
L60 Boerne
Has thanked: 173 times
Been thanked: 306 times
Re: Front Brake Cylinder AC Delco 18G94 Rebuild Kits - Out of Stock
Post by Peter60 »
I just found these ... https://www.ebay.com.au/itm/153922137282
Also if you search ebay.com.au for G60 Brakes you will find others.
These days I send old ones off to be rebuilt with stainless steel cylinders. They get cleaned up with new seals etc. Twice the price but they last way longer.
Has thanked: 7687 times
They're still around. I think the old suppliers just aren't shipping to the US any longer. Or something like that.
Thanks Peter, They don't list the vintage G60 as a fit. Can you confirm you have used them and they work?
Thanks,
RiverPatrol,
Please direct me to your shop that can rebuild the front wheel cylinders.
Thank you again,
Post by Peter60 »
Yes, only for the post 1976 G60s. Therefore the bolts are most likely metric and I' not sure about then brake lines - possible imperial.
Greetings,
Eddie installed some modern ProTex JB2047 and JB2046 wheel cylinders. Has anyone else used these?
We are field testing the brakes this weekend as we rebuild the washed out trails in the hills on our hunting property.
Any response on the use of the ProTex wheel cylinders is appreciated because the OEM wheel cylinders are not avaialble nor are rebuild kits, though the front ( i think) can be rebuilt with parts from O Reilly kit WCK13620.
If used aftermarket wheel cylinders before. Some 30 years ago. I'm sure you'll be fine. There's not much mystery on a part like that.
L60Boerne wrote: Thu Aug 06, 2026 8:11 am Any response on the use of the ProTex wheel cylinders is appreciated because the OEM wheel cylinders are not avaialble nor are rebuild kits, though the front ( i think) can be rebuilt with parts from O Reilly kit WCK13620.
I don't think this kit will work. The rubber cups are solid and the ones in the Patrol have a hole in the middle.
The correct part for the Patrol brake cups is: Seiken SC 4518R - 1
That's the original manufacturer.
In my notes I have another source: at Rockauto, use the rebuild kits for the CHEVROLET 1981-1982 LUV and 1988-1992 ISUZU PICKUP. The rubber cups are the same. 1-inch diameter. Part: BECK/ARNLEY 0717647
The above corresponds to part #ACD 18G94
https://www.oreillyauto.com/detail/c/ac ... B_FYhuCXZa
I've used the Protex cylinders before, no issues.
I might have some of the cups to rebuild the cylinders with. Although I don't think I have the covers.
Thank you RiverPatrol. If we make it back from the mountain climbs and creek fords I'll report back.
