Patrol refurb + minor upgrades
Has thanked: 5 times
Been thanked: 24 times
Post by BR_Patrol »
First off I am really bad about posting anything, but if I can tell remember I will post as I go through my low budget refurb.
So far I have swapped frames and rebuilt the engine, transmission, and transfer case. These are pretty documented but I can share insight and pics if you have questions, but I don't plan to show anything on these.
First ideas I haven't seen that I would like to share are some body repair/modifications. Starting with the commonly trusted out bed rails. I replaced these with 2x2 tubing. Little primers and seam sealer on the bottom side for rust proofing and a little Bondo cleans up the edges. But then boom, better and factory
Re: Patrol refurb + minor upgrades
Post by BR_Patrol »
Also made some decent at best rear doors. Mine were badly bend and I had some tubing and 1/16" plate laying around. So I made some overly heavy rear doors.
Post by BR_Patrol »
For anyone curious about the rolling chassis.
Post by BR_Patrol »
And as it sits today. No other different type of repairs/upgrades worth mentioning to get to this point yet.
Has thanked: 456 times
Been thanked: 791 times
Post by r1lark »
You are doing some really great work! And it looks like the whole family is involved. :clap:
Has thanked: 7728 times
Nice work! Patrol restorations are always great family projects. :D
Post by BR_Patrol »
Thanks! It's definitely a family project.
Post by TNOffroadPhiDelt »
Did you rebuild the engine? If so, where did you source the parts?
Post by BR_Patrol »
Yes I did rebuild the engine. Thankfully I found another person on Facebook marketplace who gave up on their Patrol project and had already sourced most of the parts I needed. Anything remaining I sourced on eBay.
Post by BR_Patrol »
Another easy modification solution that looks decent. Door cards from ABS plastic sheet. Really cheap and easy to transfer a shape and cut out with a Dremel bit.
