Does anyone know how to remove the rear wheel wheel bearing from the axle? I removed the threaded nut and the locking washer, but the bearing won't slide off.
Any special tools that are needed?
Thanks,
Greg
Rear wheel bearing removal
- Has thanked: 7687 times
Re: Rear wheel bearing removal
Just posted this above - As I recall having a press was a handy tool.
- Has thanked: 6010 times
Download the 1978 Service Manual that has better instructions and graphics.
https://www.60patrol.com/forum/viewtopic.php?t=1962
As RiverPatrol suggested, there you’ll find that a press is needed.
- Has thanked: 2 times
- Been thanked: 4 times
Thank you both for your help.
The 1978 manual helped me see how to use the press.
Then my electrician mind kicked in and I was able to use some unistrut and some beam clamps!
