I just need a wiper or two
- Has thanked: 209 times
- Been thanked: 107 times
I have a seemingly simple need. I just need 2 wiper blades. The blades that came with my truck were jerry rigged to the wiper arm so I threw them out. I have a bayonet type wiper arm and the tip of the bayonet is only 4 or 5mm wide which is too small for the attachment of nearly every wiper blade on this earth. The closest I have came to an answer is here:
https://www.60patrol.com/forum/viewtopi ... arm#p33575
Stamped on the inside of the wiper arm it says, "Z256 made in Japan NWB Lic. Trico" Who else has that wiper arm and what wiper did you buy for your truck?
I have ordered these, but after measuring my bayonet width of 4 or 5mm, I don;t think they're going to work:
https://www.amazon.com/LAFORMO-Stainles ... B091TKT6LD
See the pictures for reference. I compared the skinny Patrol arm with that of a conventional arm on my Jeep. Note the difference in width.
Thanks, Tom
Thanks, Tom
Tom
Modelo 1976 L60
Batalla 2200mm
Cilindrada 130 a 3956cc
Modelo 1976 L60
Batalla 2200mm
- Has thanked: 97 times
- Been thanked: 568 times
Re: I just need a wiper or two
Someone posted about using I think a Dodge truck wiper arm to replace the Patrol arm somehow but I can not seem to find the post now. Maybe someone with better search skills can find it....
- Has thanked: 7689 times
There was a discussion on inserts here: https://www.60patrol.com/forum/viewtopi ... per#p40557
- Has thanked: 6010 times
In addition to RiverPatrol comments and the link she posted, I have the same wiper arms. What happened with yours is what I did with mine years ago. I took apart a termination on the wiper arm that engages in the wiper. That original wiper was almost impossible to source, but once you remove the termination, a bayonet type is exposed (5mm or 7/32") and you're able to use some regular wipers. You can see what I refer to by looking at some photos in the link she posted.
The wipers that will fit are Carquest 11-51 or Trico 11-51
Good luck
Good luck
River, there was a more recent post somewhere but I can't find it for the life of me.....RiverPatrol wrote:There was a discussion on inserts here: https://www.60patrol.com/forum/viewtopi ... per#p40557
Thanks Patrollers! My fears were not justified as the wipers came today and they fit perfectly in my 5mm wide bayonet wiper arms. When I installed the blades in the wiper arms, they clicked in as though I was chambering a round.
The arm has "Z256 Trico" stamped on the underside of it. My Patrol is a "76 from Columbia but I am not sure if the arms are original or not, but if you have the same arms (for the guy like me who has the same problem 10 years from now and does a forum word search), these should work: https://www.amazon.com/LAFORMO-Stainles ... B091TKT6LD
Thanks again everybody.
Tom
Plus a little humor I came across at the local alternator / starter rebuild shop....
Tom
Tom
Modelo 1976 L60
Batalla 2200mm
Modelo 1976 L60
Batalla 2200mm
