Any body have a spare rebound stopper rod? Looks like I’m going to have to cut one off.
I could make one but it would be nice to have an original.
Thanks
Rebound stopper rod
- Been thanked: 52 times
Re: Rebound stopper rod
I need one for mine and will be making it. If it goes well I’ll make a couple of extras.
Bill
Bill
I had a few spare minutes today and made a door stopper rod. I had an original as a pattern which helped get the dimensions right.
In case someone else wants a guide, here’s the process I used:
24mm metal slug
7mm steel rod at 7 inches length
Drilled center in slug to 7mm +0.1mm so it fit rod tightly (now a washer)
Oxy/Acetylene to heat end of rod and peened on anvil to shape.
Heated and fullered other end of rod for detent.
Drilled 15/64th hole in first end.
Welded on washer at end hole for original finish.
Turned out nice and glad to have one more thing complete.
24mm metal slug
- Has thanked: 6018 times
