Water Temp Sensor and fuse block
Original and compatible parts
Has thanked: 48 times
Been thanked: 146 times
Post by Slackd »
Hey all,
I’m still new, still learning and trying to figure it. Thanks for all the help so far.
Two Qs:
1) looking for a replacement water temp sensor for ‘69 L60
2) wiring up my new kick ass stereo today, cracked the fuse block. Anyone know where I can get another?
Has thanked: 7690 times
Re: Water Temp Sensor and fuse block
First rule of owning a Patrol: Don't break the parts you have because they are too hard to come by.
That being said, someone found some fuse blocks recently.
viewtopic.php?f=15&t=6069&p=48956&hilit=fuse#p48956
I may have the parts that you need. When I get back home I will try to remember to check and see what I got tucked away and let you know.
Post by Slackd »
Thanks Justin. I think I’m good. I ordered a new 6 fuse block from Amazon (not NOS but should work fine, $12) and I also ordered the correct (hoping) water temp sensor.
I’ve only had this L60 a few weeks and it’s been an interesting learning curve. Lots of issues to resolve including timing, hydronic clutch fluid leak, carburetor etc.
Dave
