Sliding Side Window Install
Post by OU10645 »
I am looking for a drawing, diagram, pictures or instructions on sliding side window installation for my 1969 Patrol.
Has thanked: 7740 times
Been thanked: 2482 times
Re: Sliding Side Window Install
Maybe this will help: viewtopic.php?f=41&t=1675
Post by OU10645 »
Thank you River Patrol for the info. Good job! Would it be possible for you to give me some instructions on how you would install the sliding window seal? The seal I have has the 2 grooves for the windows to slide in. The seal is in one long piece and buckles in the curved corners of the window opening. It looks like I will have to install it in pieces. One piece on the bottom, one piece for the top and one piece for each side. Is this right?
You'll want to install it in one piece. The instructions I linked describe that. Do not cut the seal into pieces. When you work it around the metal frame that is inside the seal the buckles will work out.
Post by OU10645 »
Thank you!!
