Fuel tank sending unit
Posted: Fri Jun 18, 2021 1:49 pm
by Lriwater
Hi,
I am hunting a fuel sending unit for a '66 Patrol. Currently, the gage itself mounts to the top of the tank, which baffles me to be honest, as you would have to go back there, remove the cover, and check it...
There is a fuel gage on the dash. So, I would like to get a sending unit that works with the stock fuel gage.
Thanks,
Chuck
Re: Fuel tank sending unit
Posted: Sat Jun 19, 2021 9:07 am
Lriwater wrote:Hi,
Sounds as though Rickheiserman’s mechanic might have worked on the Patrol at one time. :lol:
Is the wiring to the gauge still there? Sending units are becoming hard to find. If they modified the opening of the tank to fit the custom gauge they may have made it difficult to go back to the original sender. eBay has the sometimes but usually the later style that is secured with a lock ring, you’ll want the kind that is secured with screws.
Posted: Sat Jun 19, 2021 6:44 pm
by L60Boerne
I can state that the ones for sale on ebay from S. America work but read in reverse, The signal sent shows empty when full and full when empty.
Posted: Sat Jun 19, 2021 10:43 pm
by Lriwater
The tank doesn't seem to be modified. It has 5 small machine screws. Is it possible to rewire the S. American one to read correctly?
Thanks for your responses!
Posted: Sun Jun 20, 2021 7:21 am
by L60Boerne
I had a guy try to rewire mine but he was not successful. However, he might not have known how to do it either. It seems like to me it should work. I sent my best gauge cluster, found here from forum members , to a gauge rehab shop in MN. Plan was to simply reverse the lettering but then the gauge shop closed with no attempt to return my gauge. :violin:
Patrolling in Paradise,
Posted: Mon Jun 21, 2021 10:46 am
by Lriwater
L60Boerne wrote:I had a guy try to rewire mine but he was not successful. However, he might not have known how to do it either. It seems like to me it should work.
I'll get the one from S. America and try to rewire it. I have enough electronics experience to be dangerous. If successful, I'd be glad to do yours.
Posted: Tue Jun 22, 2021 2:25 pm
by L60Boerne
Thank you, that would be very much appreciated. I always thought it was possible.
Posted: Fri Jul 30, 2021 6:47 am
by reykyle
I'm having the very same issue... I tried to switch wiring on the fuel sending unit on the tank, switching posts. Didn't work, but I'd love to know other "re-wire" options.
