Frame Crossmember
Posted: Mon Feb 11, 2019 4:13 pm
I picked up a new frame from a member last year. I am now getting it ready to be galvanized.
The frame is relatively clean and is rot free. However, I know the crossmembers on these things are known to rot. What should I do to test a crossmember that looks solid? Should I cut a hole in the top and look inside? I can then reweld the plate back on.
Should I add drainage holes?
I am curious to hear your thoughts. I want to do this once, and right.
