Steering gear outer race OR steering box needed
Has thanked: 11 times
Been thanked: 22 times
Post by patrolhead »
We are missing one of the bearing gear outer races from the steering box on our 67 project - it is part number 48025-44000 (#28 - Bearing Gear) from the parts manual, of course not available. Anyone have one or even an extra steering box we can get a hold of to pull one from? Would greatly appreciate it!
'64 drivetrain/'67 chassis project on-going
Has thanked: 6029 times
Been thanked: 1608 times
Re: Steering gear outer race OR steering box needed
patrolhead wrote:We are missing one of the bearing gear outer races from the steering box on our 67 project - it is part number 48025-44000 (#28 - Bearing Gear) from the parts manual, of course not available. Anyone have one or even an extra steering box we can get a hold of to pull one from? Would greatly appreciate it!
I did an internet search and found that it might correspond to NSK R20-4 A (NSK is the manufacturer). You can compare the dimensions of the other bearing that you still have to this. I couldn't find any vendor in the USA.
This bearing has the following measurements:
OD: 55mm (2.1654")
ID: 20mm (0.7874")
Thickness: 16mm (0.6299")
The following site has the above info (it's in Ukraine!)
http://www.noc.ua/en/online-catalog-bea ... le=R20-4+A
Thank you! I found a steering box to rob one from but this is good info for future searchers.
