Re: Disk Brakes
Been thanked: 15 times
Disk Brakes
Post by Monkey0726 »
I'm working on a disk brake conversion front and rear for a 1967 L60. I'm using rotors and calipers from a 1989 chevy 1/2 ton 4x4. I had to have a machine shop mill out the center hole bigger so it would fit over the Patrol hub. I downloaded the cnc program from EMachineShop.com and ordered the parts to make the brackets. I don't know how to upload photos but I will try to get some up soon.
Has thanked: 7740 times
Been thanked: 2482 times
Re: Disk Brakes
Awesome! Please keep us posted.
Re: Disk Brakes
Re: Disk Brakes
Re: Disk Brakes
Has thanked: 6027 times
Been thanked: 1607 times
Re: Disk Brakes
Congratulations! It looks amazing and like it always belonged there. :clap: :clap: :clap:
Remember, it's cheaper by the dozen... I'll bet that a number of members here will want something like that.
Once completed, please post all the details about the process.
Has thanked: 27 times
Been thanked: 114 times
Disk Brakes
Post by Mattbob53 »
Looks really sharp nice work. Did you have to change your studs out?
Re: Disk Brakes
I will probably replace the 2 longer studs that used to work with the drum brake set up. They do not interfere with anything so you could leave all the studs stock if desired. Once I have this completed I will let you guys know if it actually works. On the front I had to grind a touch off of the calipers so they would clear the casting on the axle housing. It's a tight fit but I think it will work! :D
Re: Disk Brakes
Post by Mattbob53 »
Any update monkey ?
Re: Disk Brakes
I have fitted the brackets on the axels and installed the disks and calipers with success. I had to grind a little of the caliper and axle housing for ample clearance on the front. Everything's seems to be fitting well. I ended up removing all of the body work from the frame to properly prep everything for paint. I put the cab back on the chassis last night and picked up all of the new brake lines today. I'm hoping to test the system in a few weeks. The engine and transmission are currently at an engine shop getting rebuilt so it may be a few weeks before I can test them out. I would be glad to text you some pics.
