Page 1 of 2
Waterproof Distributors & other OEM Parts
Posted: Fri Mar 04, 2016 6:51 pm
by mtnPatrol
I have some oem and non-oem parts from a 68/69 that I would like to trade for some other parts that I need for my Patrol. You can see what I'm looking for in this thread: http://www.60patrol.com/forum/viewtopic.php?f=17&t=4141. If trading isn't an option I would also sell them.
  • 2 - Hitachi waterproof distributors. One is complete. The other is missing the drive gear and one plug wire though the screw end is there.
  • 2 - Original brake / tail lights. Plastic lens. One light is complete. The other is missing the lens and chrome bezel. Pictured below.
  • 1 - Koito indicator light receptacle. Just the receptacle and wiring. Picture: http://www.60patrol.com/forum/download/file.php?id=6392.
  • 6 - Nabco wheel cylinders. They need rebuilding.
  • 1 - Tokico master cylinder.
  • 1 - Nippondenso coil.
  • 5 - 15" Split rims. Good condition.
  • 1 - Toyo tire. Almost new.
  • 1 - Roof bow with the 2 connectors. Great condition.
  • 1 - Mitsubishi voltage regulator. Picture: http://www.60patrol.com/forum/download/file.php?id=6392.
  • 1 - Rochester 1 barrel carb. Casting #7004497-C-1. Pictured below.
  • 1 - Nichira Heater. This mounted under the passenger seat to provide heat for the back. I have verified the core holds water and the blower motor works. It is missing the manual lever control but was controlled either by the existing front heater switch or a second dash switch. These apparently were used on Datsun 320 and 520 trucks. Picture: http://www.60patrol.com/forum/download/file.php?id=6507.
Jon
Re: Waterproof Distributors & other OEM Parts
Posted: Fri Mar 04, 2016 8:12 pm
by mattmctree@gmail.com
Could you send me a pic if the Rochester ? What are you looking to get for ut
Posted: Sat Mar 05, 2016 9:04 am
by mtnPatrol
My phone does a terrible job inside. Let me get it outside and get a few pictures for you. Either today, if it doesn't rain, or tomorrow.
The only item I have seen for sale is the waterproof distributor so I don't really know the value of any of the other items. What is a fair value? I will see if I can find some examples.
Posted: Sat Mar 05, 2016 12:06 pm
I'm not overly sure of the value either. I'll do some research as well . If you can get me close up shots of all sides and the numbers on the carb that would be helpful. Min broke during disassemble and I'm going to try and fix it but need another carb just in case.
Posted: Sat Mar 05, 2016 6:05 pm
by mtnPatrol
Raining now but I was able to get out this morning while we had some sun. The casting number on the bottom of the bowl is 7004497-C-1. I definitely can't capture that with my phone.
Posted: Sat Mar 05, 2016 6:14 pm
by mtnPatrol
Can someone confirm that these are indeed brake lights?
Posted: Sat Mar 05, 2016 6:34 pm
Yes, those would be brake lights for a '68.
Posted: Sun Mar 06, 2016 7:54 pm
by mtnPatrol
Are Patrol fenders that aren't in good shape something that people still want? I don't have a sense for the whole parts supply and demand. I ask because, if it isn't something someone would want, I can cut it up and put it to use.
Posted: Sun Mar 06, 2016 8:13 pm
When people are looking for fenders or other body parts it is usually because they want ones that are in better condition than the ones that they have. They usually don't want ones that aren't in good condition.
Posted: Wed Mar 09, 2016 8:42 pm
by mtnPatrol
Updated list.
