Hood Windshield Bumpers
Has thanked: 15 times
Been thanked: 48 times
Post by Marshall »
I searched the forum looking for the hood windshield bumpers and found that some people make them out of hockey pucks, and a few links that were expired. Does anyone have any source on these? or a replacement part? I have a 67, so they are a two hole bolt attachment. Thanks!
Also, is there a support brace under the hood that gives stability to prevent the hood from denting in? It seems to me it would need something as to not create large pressure dents, but maybe not.
I found this pic, these look correct? Where to find? :think:
Re: Hood Windshield Bumpers
Datsunland SoCal:
http://www.datsunlandsocal.com/mm5/merc ... _Code=P129
In fact, Mike has cranked out reproductions of most of the Patrol's rubber pieces:
http://www.datsunlandsocal.com/mm5/merc ... atherSeals
Post by Marshall »
Thanks Rob! Exactly what I needed. A bit expensive, I might try my hand at cutting some pucks first...
Post by Marshall »
So, I couldn't muster up the dough for the hood bumper reproductions, so tried what someone mentioned with hockey pucks. I think they turned out pretty well. I mounted them on with bolts and extra wide washers under the hood for more support. Is this all for the hood bumbers as far as support under the hood? Was there ever a larger steel plate, or cross beam to help with the weight of the wind shield?
Has thanked: 6013 times
Nicely done!
The originals didn't have anything so you're better off now. They were a single piece rubber with little legs going into the holes.
They turned out great!
As a reminder- Before the first time you try to lay the windshield down on those bad-boys, be sure to apply generous amounts of WD40 or PB Blaster to the hinge pins...!
Post by Marshall »
Thanks guys! I actually already folded it down - it was lubed a bit and went down easily. :dance:
zed
Has thanked: 203 times
Been thanked: 678 times
Post by zed »
Greetings all,
I have identified two (2) styles of Hood Windshield Bumpers:
Keith88238824
Can anyone identify the application years of the different styles?
Thanks,
