pinion seal
pinion seal
Does anyone know of the part for the pinion seal. Nissan says it is no longer available am trying to cross reference it. Hopefully someone has already found a suitabale replacement. Thanks Vern
pinion seal
Sorry, Thae pinion seal is for the rear end and front of transfer case, both numbers are supposed to be the same. Vern
pinion seal
The front and rear differential pinion seals, as well as the seals at the transfer case, are all the same. The Nissan part number is 38189-44000 I'm trying to find an alternate part, or at list the measurements (id, od, thickness).
