Replacement parts for Helmar P40 Distributor
Original and compatible parts
Here are some replacement parts for the Helmar P40/H20 distributor (Century model 22100-c7000):
Replacement Cap:
http://www.helmarparts.com/product_p/22162-v2502.htm
Rotor:
http://www.helmarparts.com/product_p/22157-05m02.htm
http://www.helmarparts.com/product_p/22145-89901.htm
or
http://www.helmarparts.com/product_p/37z-02-cp901.htm
or
http://www.helmarparts.com/product_p/4942379.htm
(any of the above will work)
Condenser:
http://www.helmarparts.com/product_p/37z-02-cd901.htm
or
http://www.helmarparts.com/product_p/22102-d1100.htm
or
http://www.helmarparts.com/product_p/4942372.htm
Complete Tune up kit (includes point, condenser, and rotor) :
http://www.helmarparts.com/product_p/h20%20ignition.htm
To convert to electronic ignition:
The Pertronix Ignitor kit for this distributor is: #1761 or #1762 (either will work)
The Pertronix Ignitor II kit for this distributor is: #91762 or #91762 (either will work)
Has thanked: 6017 times
Been thanked: 1601 times
Re: Replacement parts for Helmar P40 Distributor
Thanks for posting this comprehensive list.
Actually the Pertronix Ignitor kit #1761 also works. It's the one I've installed.
The real advantage of the Ignitor II will come between 3000 and 5000 rpms, so not that much in real terms for the Patrol, with the added cost, although some of the other specs look very interesting.
http://www.pertronix.com/prod/ig/ignitor2/default.aspx
Has thanked: 19 times
Been thanked: 8 times
Post by Socalwrencher »
Estaban, that's what i thought, I was lead to believe it was the 1761. I have the Helmar on order
Alex
Don't leave out the Water Protect dizzy version is 1763.
edit: sorry......we are talking just the Helmar dizzy :oops:
So the 1761 and the 1762 will both work in the Helmar dist with out any mods?
Alex
Socalwrencher wrote:So the 1761 and the 1762 will both work in the Helmar dist with out any mods?
Sounds like it-
I ordered the 91762 Ignitor II and the plate matches the mounting screw layout of the points plate perfectly, and Esteban confirms that the 1761 does as well.
I did an image comparison on Google of all 4 (1761, 1762, 91761, and 91762) and they all look the same.
The reason I went ahead and paid the extra for the Ingnitor II is for the adaptive dwell control- I figure this will give me some more efficiency and mpg at cruising speeds. I agree that from a power standpoint the benefits are going to be in the higher RPMs, but you never know when some joker in an FJ40 is gonna want to drag race, right...? I need to be prepared. :twisted:
Hey Robert i made a CCW 6 cyl HEI using the 289 302 dizzy but i can't get the wobble out. So i went ahead and ordered the Helmar. I would have been nice to get that to work.
Alex
Socalwrencher wrote:Hey Robert i made a CCW 6 cyl HEI using the 289 302 dizzy but i can't get the wobble out. So i went ahead and ordered the Helmar. I would have been nice to get that to work.
man, you should have called me - If you have the HEI configured to work CCW, then I could have sent you my adaptor to use - mine had zero wobble. Let me know if you still want to try it...
i'll ship it to you, you get it to work and then let me know how much i owe you :)
Alex
Socalwrencher wrote:i'll ship it to you, you get it to work and then let me know how much i owe you :)
If you ship it to me, and I get it to work, then you may never see it again.... :twisted:
I'm just kidding - yeah, if you want to try that, I'm game. I'll txt you my address.
