Patrol Tune Up
Has thanked: 12 times
Been thanked: 13 times
Patrol Tune Up
Post by Andrew »
Hello, I am working on a tune up and wanted to know if anyone has found these parts at a local parts store like Napa. I found these on Nissan parts zone. Am I missing any parts?
**162-46502 CAP DISTRIBUTOR $25.55
**145-58000 POINT-SET $7.69
**157-46502 ROTOR HEAD $4.96
**450-80029 S/PLUG CABL SET $47.09
Has thanked: 6028 times
Been thanked: 1608 times
Re: Patrol Tune Up
I have the non-waterproof distributor. The numbers you posted are correct. However, good luck with NissanPartsZone. For me it has been a disappointment on three occasions since you place the order, and a couple of hours after that you receive an email stating that the order has been canceled due to parts being no longer available.
Hope some other members have a source for these items.
Has thanked: 7744 times
Been thanked: 2482 times
Re: Patrol Tune Up
As Esteban pointed out, those parts are for the non-water protect distributor. Your Patrol most likely has the water protect distributor on it. In which case points and condenser are pretty impossible to find. The w/p cap is still available, and the wires. I'm not sure about the rotor. This is one reason why some people have gone to the Pertronix electronic ignition.
Re: Patrol Tune Up
RiverPatrol wrote:As Esteban pointed out, those parts are for the non-water protect distributor
Sorry for the confusion I created. The parts that Andrew posted, do correspond to the water-protect type distributor.
Re: Patrol Tune Up
Andrew, I would check these dudes if you really want points but the pertronics is a better deal, better performance, waterprotect (1763LS), and looks original in the engine bay:
http://www.ebay.com/sch/m.html?_odkw=&i ... &_from=R40
Re: Patrol Tune Up
Post by Andrew »
Pertronix sounds like a good idea. Any idea on a place to find a cap quickly?
Re: Patrol Tune Up
Re: Patrol Tune Up
Post by Andrew »
Thanks!
