Page 1 of 2
Driveline Issues
Posted: Sat Jun 01, 2013 5:30 pm
by G60michael
Well the new G60 I picked up has a driveline issue,and front Diff jams up when put in to 4wd. I jacked the vehicle front wheels of the ground and Acivated 4wd on the transfer Leaver, then I rotated the wheel around with the hubs "Un-Locked" no issues. Then I Lock the Drivers hub in and rotate 1/4 till 1/2 a turn of the wheel then the front tailshaft stats Vibating down near the front diff ??
Any ideas
Re: Driveline Issues
Posted: Sat Jun 01, 2013 6:39 pm
Sounds as if the hub might be toast, or even the diff. You should have a few spares laying around, swap it out.
Posted: Sat Jun 01, 2013 7:29 pm
by G60michael
well its now in 2 low, I removed the Front tail shaft,Now there is no noise present at this stage,i have a feeling it could be the pinion Bearing seized or collapsed ?
Posted: Sat Jun 01, 2013 9:12 pm
Well, it seems that you're narrowing the problem. Try to see if rotating by hand the pinion flange at the diff you can feel something. Most probably you have a bad bearing from what you describe. Probably caused by rust rather than wear.
Good luck with this, and report your findings.
Posted: Sat Jun 01, 2013 10:33 pm
by G60michael
it started to rain so I haven't had a chace to do any more Testign to the Front diff. I am half way through Flusing the cooling System out in the new G60, for those that haven't seen it meet the new G60, I am in Search of a name still for this G60, An Ideas on a name ?
Posted: Sat Jun 01, 2013 11:37 pm
by miksum56
G60michael wrote:it started to rain so I haven't had a chace to do any more Testign to the Front diff. I am half way through Flusing the cooling System out in the new G60, for those that haven't seen it meet the new G60, I am in Search of a name still for this G60, An Ideas on a name ?
Lead Red
Posted: Sun Jun 02, 2013 8:32 am
'Mater
Posted: Sun Jun 02, 2013 9:25 am
by sleepyzzz
RiverPatrol wrote:G60michael wrote:it started to rain so I haven't had a chace to do any more Testign to the Front diff. I am half way through Flusing the cooling System out in the new G60, for those that haven't seen it meet the new G60, I am in Search of a name still for this G60, An Ideas on a name ?
'Mater
mater works for me
Posted: Sun Jun 02, 2013 4:19 pm
LOL! He's even got a broken headlight, just on the opposite side.
Posted: Sun Jun 02, 2013 6:22 pm
by Swerve
Mater, love it, look similiar
