1979 MWB G60 - Parts Patrol
Has thanked: 149 times
Been thanked: 310 times
Post by G60michael »
Well you probably read my other post about my 1966 MWB Softop and my 1978 Hardtop G60’s.
Well what they have in Common is that they are Both driven Regularly, while this one however doesn’t get Driven, it is mainly a Parts donor Vehicle, but will be also a Paddock Basher if I can manage to get the Spark to the plugs, as it only seems to go as far as the Points.
This Patrol was purchased off a G60 enthuisist, only payed $150 for it, I figure if I sold it when Scrap Value is up, I would most likely get that for it anyway, but why Scrap a Rare old Gem.
Starting of the Intro of the G60 it is a 6/1979 G60 MWB Softop, Original Motor and is Believed to have spent most of its life around the Base of Dorrigo Mountain NSW ,on the Farms.
This is my only G60 that has a Sticker/Decal on the Rear Quarter Panel ,my 66’ has a metal Plaque, while my 78 G60 doesn’t have any Decal or Plaques on it, was this only used on several G60’s or did All G60’s originally have the Decals ? Like the Majority of Aussie G60’s it is rusted out in the Rear Quarter Panels
The Front hubs are also a Different Set up to both of my other G60’s,there an Automatic Set-up, I read once somewhere that these Style hubs were original on all G60,is that True ? Both of my other G60 have Heavy Duty Selectro Hubs. Image
Having been working on Farms over it Life, I think this patrol has seen its Fair Share of Cow Manure, which helps sum up the fact that the Undersides of both front Guards have started to rust out and now eventually have rusted the complete way through, for those who also live on Farm of Cattle Properties would know how quickly Cow Manure will rust things.
I haven’t had the Engine running in this G60 as of yet, but the Radiator in it seems in Great Condition, it does also have a Sticker of a Radiator Reconditioning company. The Radiators in these old G60 tend to fall apart over time, I have seen it on a few G60 on the internet and in paddock find G60’s, but I am Lucky, all of mine are perfect.
One of the Big bonuses of this G60 over my other 2 is that the Handbrake actually works Great, all they usually take is Proper Adjusting, but the G60’s Handbrakes weren’t a Strong Point.
The front Grill has a few dints in it, but it also has a few holes along the centre pieces, assuming that this may have also had the big “NISSAN” Grill on it, like the later G60’s Did. Image
Has thanked: 7712 times
Re: 1979 MWB G60 - Parts Patrol
Well yes, anyone with multiple Patrols has at least one parts vehicle. Nice pictures, your camera takes good close ups.
I can solve the sticker vs metal plate for the rear name badge mystery for you. Patrols had a metal plate on the rear until 1967, then they started using the sticker. If your other G60 is missing the sticker it may indicate that the panel was repaired and/or painted in the past.
Regarding the front hubs; what this G60 has is what all Patrols rolled out of the factory with. They are the standard fully locked hubs. Dealerships or new owners always installed the freewheeling hubs that most Patrols have now. The most popular brand of freewheeling hub used in the states was the Warn hub. These allow you to manually lock and unlock the front hubs depending on driving conditions. If a Patrol is used strictly on the farm then freewheeling hubs are not necessary. They are mainly used for pavement driving, to improve fuel consumption and have less wear and tear on the front when it isn't necessary.
Nice paint job on the engine. ;) Practicing?
well I finally got the old red G60 going, and this arvo I drove I for the first time, the motor runs quiet well, but is very loud as it has no exhaust, it also seems to steer a lot easier than any of my other G60's for some reason. When you look this G60 parked besides any of my other 2 G60's you really Notice how much higher it sits than the rest, as someone made some home-made but very beefy extended shackles front and rear.
Tomorrow afternoon I will bolt back in the rear tail shaft I removed for no reason :? and then I will be able to drive around in either just rear wheel drive of 4wd instead of front wheel drive.
Also the fuel pump In it didn work ant all,so I just bolted in the Blue G60's pump to test it out
Nice! :handgestures-thumbupright: It's interesting that this is your newest G60 buy it's in the worst condition. Cool that you drove it around in FWD, I've never tried that. That is something to keep in mind for anyone that ever breaks a rear axle - you can always drive it home in FWD!
Has thanked: 195 times
Been thanked: 54 times
Post by miksum56 »
RiverPatrol wrote:Nice! :handgestures-thumbupright: It's interesting that this is your newest G60 buy it's in the worst condition. Cool that you drove it around in FWD, I've never tried that. That is something to keep in mind for anyone that ever breaks a rear axle - you can always drive it home in FWD!
I drove home that way 30 years ago from Redding ca. like that. No gear conflict, no prob.
Tomorrow will be a sad day ,Farwell to the old girl :( :cry:
