Wierd sounds...
Wierd sounds...
Have anybody had any wierd bearing sounds when letting go of gaspedal driving in 4x4? I checked all bearings in the transfercase and axles. The driveshafts are also ok. If I lock the hubs, but drive in 2 wheel drive then everything is quiet. Nissan Patrol MK 1985 SD33 5 speed Jan-Eric Enlund / Finland
- Lurker
Wierd sounds...
; moro! mun patrolli pit¤¤ my¶s jyrin¤¤ kun n 100km/h ; nelivedolla helppaa kaasust ni jyrin¤ alkaa ! se on ihan normaalia mun ; mielest se johtuu siit¤ kun jakolaatikos ei ole tasauspy¶r¤st¶¤. ja kun etu ja ; taka akseli py¶rii kuitenkin hiukan eri nopeuksilla:
Wierd sounds...
the mq hub lock nuts in the front loosen off causing some sound .this is a common thing with the front end.if u take this apart buy new lock washers that fit betwwen the nuts.the tab breaks off causing the nuts to loosen Post your free ad now! Yahoo! Canada Personals
Wierd sounds...
Is the transmission auto or manual?; ; ; ; ; ; ; Talk to ya later, Jon ; ; ; ; Personal Info:; ; If you are what you eat... I must be CHEAP, QUICK, and EASY!My WebsiteAF4CYahoo Messenger ID: Jonx4x4MSN Messenger addy is this e-mail address.; ; IFSJA forum ID: BIG BAD JON Member# 2320N4W forum ID: Jonx4x4IH8MUD forum ID: Jonx4x4; ; Previous message(s):..>From: "PatrolOffroadTeam" >Reply-To: "Nissan Patrol Club Albuquerque" >To: "Nissan Patrol Club Albuquerque" >Subject: Re: Wierd sounds... >Date: Fri, 27 Feb 2004 14:31:33 -0800 > >We attempted to deliver this message to you with HTML formatting. However, your e-mail program does not support HTML-enhanced messages. Please go to your E-mail Settings for this group and change your E-mail Preference to "Text only". >http://groups.msn.com/NissanPatrolClubA ... tings.msnw > >MSN Groups > Stay informed on Election 2004 and the race to Super Tuesday.
Wierd sounds...
Dear Jan-Eric,sometimes we miss some minor details like the driveshafts.You could check the universal joints, most of the Patrols universal joints have a place to grease them.They are little bolts that cover the hole for grease-nipples between the crosses of the U-joints.If the noise is severe then it's time to change the U-joints.You can also check the gear-oil level in the transfer-case.Mines made some screeching sound in 4wheel-drive and it was low gear-oil level in the transfer-case.I do hope these info could be of some help to you. From: Roland Christiaans
