Front Brake Hoses -'65 L60?
Hi. Can anyone tell me the correct front brake hoses for a 1965 L60? The hoses listed in the Compatible Parts section (NAPA numbers #5784 and #11190) are the right length, but are smaller in diameter and have smaller fittings than the ones on my Patrol. They may fit later models but won't fit my '65.My Patrol's front brake hoses have threaded anchor ends that use nuts instead of the clip anchors on the #5784 and #1190 hoses.Any help would be appreciated. Thanks!
I couldnt tell you which ones would or wouldnt work, BUT I can tell you that the hoses would use the same threads as Chevies, Fords, and Dodges. Take off on a romantic weekend or a family adventure to these great U.S. locations.
Jon,Thank you. I replaced my rear axle hose about five years ago with an off-the-shelf NAPA hose. I wish I could remember the number as the front and rear hoses seem to be about the same length. I was hoping someone could give me NAPA or other part numbers for the front axle and front wheel hoses.But thanks for your reply!
; I have the numbers written down at home for the ; front and rear flexible brake hoses to the axles, I'll post them ; tommorrow.; ; David CollinsHood Canal ; Communications
i got my hoses from nissan about 6 months ago..here are the numbers.. 46201-46502-front hoses,as i got 2 in 1 package. 46210-46502-rear hose. hope this helps
..paul ps..mines a 66..so should be same type
; Front and Rear frame to axle tee hose ; (rubber) is Napa 36065; Axle to backing plate tee front rubber Napa ; 36507 (both sides); Front axle drivers side metal hose from axle tee ; to backing plate tee 813-1204 (3/16 x 20"); Front axle passenger side metal hose from tee ; 813-1206 (3/16 x 40"); ; David CollinsHood Canal ; Communications
Perfect! I thank you, and my Patrol thanks you! I hope the new hoses last 44 years!
