frame # location/rubber windshield rests
frame# is stamped on the right frameside member at the front end,and the engine s.n.is on the right side of cylinder block,front lower corner
the vin plate will have the year stamped in it the one on fire wall hood bumpers obsolete time to try to find something that will work
You can find the chassis number stamped on top of the right hand side of the chassis frame, looking inside the engine compartment. It's very close to where the exhaust pipe is located. You will need to clean that part of the frame member to find the numbers.I will try to find some info regarding years and numbers.
Here are a few examples of 1962 Vin 's 1962 L60 L60-2-00101A 1962 KL60 L60-2-00675 Here are a few examples of a 1964 Vin. 's 1964 KL60 4L60-02328C 1964 L60 "Hogan" 4L60-01116
If it works, I would be a customer for you. I have a 63 but no windshield rests. Do you think you will be able to make some extras?
