Set Point Gap
Locked
Set Point Gap
Post by npca-stryder2000441 »
I feel like I am wallowing in ignorance. Could someone please explain to me how to set point gap? When I attempt to loosen point screw. the whole plate seems to move. The screw moves laterally in a little slot but does not seem to effect gap. ?!? My dwell is reading about 34 degrees. Is this close enough?
Set Point Gap
Post by npca-gruntly »
just loosen the screw a little bit then pry it with a screw driver in the slot with the pimple in it set to .20 thou about ok
Locked
