gas vent on top of tank?
Posted: Tue Sep 25, 2007 1:47 am
by npca-66-60
So i am tearing through the back end of my truck getting all the lights and stuff rewired and I discover a plastic tube (1/2 -5/8 OD) that travels from the top of my gas cap, on the inside of the truck, to the tank. But.......when I really start looking at it the end above the cap is plugged with a metal piece and then I start looking around and follow the tube to the frame and its just tied off. I pull the panel above the gas tank to see if there is a vent. Sure enough there is and its fits the tube perfectly(length and size). I hook it back up and start thinking about why it would be like that. I recently got my patrol and whenever it sits in the garage a day or so and I go in there the smell of gas is pretty powerful. What is the deal.....I have the original carb and a new Holley pump the last owner installed. Any ideas?
Posted: Tue Sep 25, 2007 10:14 am
by npca-abuelo442
The vent in the gas tank helps when you're refueling, and it's crucial for it. Otherwise, it will be painfully slow to fill up. Could be the source of the smell in your garage.
Posted: Tue Sep 25, 2007 10:00 pm
by npca-67l60
gassy smell that's not good id be checking all my rubber hoses, and the fill neck especially useing a standard quick disconnect fitting works great just unscrew the main line and screw it in & apply 6psi and look and listen for leaks youll be supprised i test all my tanks this way if you want to test the whole sys hook in to the vent hose you found good luck with the search
Posted: Wed Sep 26, 2007 9:47 pm
by npca-honda guy
yeah the vent tube goes to the filler neck and then right back out again, straight to atmosphere. it can be a source of fumes but a leak of some sort is also possible. I can say that a pressurized gas tank is like a huge bomb with a torch for a fuse. just be careful. i would just cap the vent tube and see if the smell goes away. then you know that was it.
