Miller's 1972 MWB
Has thanked: 84 times
Been thanked: 327 times
Re: Miller's 1972 MWB
Post by miller »
Yes if you had a patter for that plate you'd be set. Take it to a CNC shop a get them to pump you out a few, I'm sure others would be keen for one.
Post by miller »
miller wrote: Image
See Swerve, nothing that can't be fixed.. Tell the rumour mill not to worry themselves ;)
Has thanked: 104 times
Been thanked: 175 times
Post by Swerve »
Looks like both sides to me ?
Post by miller »
Swerve wrote:Looks like both sides to me ?
Just drivers side
miller wrote:
miller wrote: Image
Okay, I missed out.....what changed and those shackles are interesting. What is the smaller bolt under and behind the top bolt on the hangers? A stop/block mechanism?
BTW, my spellcheck says you spelled rumor wrong? ;) ;) ;)
Post by Swerve »
right chassis rail is bent
Post by miller »
bosque wrote:Okay, I missed out.....what changed and those shackles are interesting. What is the smaller bolt under and behind the top bolt on the hangers? A stop/block mechanism?
Just showing Steve my bent chassis rail. The shackles are the anti inversion type. You're right, the bolt stops the shackle inverting and jamming against the chassis.
Rumour has is your American spell check is wrong ;)
I like the shackles...are they stock height? Who makes them?
miller wrote: Rumour has is your American spell check is wrong ;)
I should listen to you about correctness?.......... :doh:
...What do Australians put in their pockets that Americans throw away? :geek:
Post by miller »
bosque wrote:I like the shackles...are they stock height? Who makes them?
These are the shackles.. http://www.superiorengineering.com.au/p ... ts_id=1483
miller wrote:I should listen to you about correctness?.......... :doh: ...What do Australians put in their pockets that Americans throw away? :geek:
Yep coz I was brung up real proper! ;) What do we have in our pockets?
Post by miller »
So I acquired a soft top last weekend and on Wednesday I dropped it off to have the windows replaced.
It still needs a really good scrub as it was sitting under a guys bench in his workshop since the mid 70's!
Im a little disappointed they had to replace the webbing on the back window. If I had know they needed to I should have got it done in green to blend a little better. I also got them to repair a rip on the back flap.
BEFORE:
Image Image
AFTER:
