G60 Build South Africa
Has thanked: 3 times
Been thanked: 43 times
Re: G60 Build South Africa
Post by grips »
Broken rear side shaft. Seems impossible to find a replacement C200 rear shaft in South Africa. Option 1 is to upgrade to H260 diff at the back. Option 2 is to make a custom side shaft just to get the Little Patrol mobile in the meantime.
The video from the incident :D Too much power and age catching up.
https://www.youtube.com/watch?v=72TRrSb ... e=youtu.be
Post by grips »
Some action :lol: prior to the side shaft failure
https://www.youtube.com/watch?v=bywlsFp ... e=youtu.be
Post by grips »
Latest mods spare wheel carrier.
Post by grips »
The 302 is a little wide for the Patrol engine bay. This forced us to use the stock 302 cast Iron manifolds on the Edelbrock Heads robbing s few horses.
This were cured by the fitment of 351W manifolds that were port matched to the heads.
With limited space a custom shorty exhaust were build.
Post by grips »
Solved the broken side shaft problem. I made one :lol:
Could not find a C200 rear shaft in SA . Machined down a shaft from a FJ 45 Cruiser. Few little mods and it were on the go
Has thanked: 6025 times
Been thanked: 1607 times
Fantastic! Congratulations.
Can you post some more pictures showing the splines and also the threaded portion for the bearing nut?
Has thanked: 7740 times
Congratulation! That's a very diligent and creative way to solve the problem. 8-)
Post by grips »
Esteban wrote:Fantastic! Congratulations.
Sorry did not take a closeup of the splines. Used a locking collar and snapring to replace the bearing nut.
Post by grips »
RiverPatrol wrote:Congratulation! That's a very diligent and creative way to solve the problem. 8-)
Thanks
Has thanked: 22 times
Been thanked: 113 times
Post by desertrat »
I like it.
