faux40 wrote: Now, here's the big question, if I were to spray a bunch of carb cleaner (say, 10 ounces -- about 1/2 a bottle) down the galley and it does its job and breaks through, would I need to change the oil and flush out the galley before running the engine, or will enough of it evaporate or mix with the oil that I needn't worry about messing up bearings?
Thanks so much for the help! I really appreciate it!
My opinion is that you should plan to drain and change the oil regardless of what you do to clear the blockage (I like the idea of snaking a speedo cable around in there, that's a good idea)
And if you are going to change the oil anyway, then another suggestion I had would be to thin the oil down with a solvent (like a gallon of naptha or laquer thinner, and then run it thru the system by spinning the oil pump with the drill (CAUTION- do not run thinned oil through it with the starter- keep the cam and crank stationary , and drive the oil pump with your drill if you plan to try this technique.) after you have flushed everything with solvent, then drain it, re-fill with clean oil, and also run the clean oil through it with the drill before you attempt to start the engine.
