Parting two 67's
Parts for sale, or free
Has thanked: 181 times
Been thanked: 174 times
Re: Parting two 67's
Post by RMP&O »
I do have the dash map light assembly with glass cover.
I have two original gas caps, neither has a key.
I do have a spare engine hand crank.
I don't have any more wiper arms, just the one set.
I have an un-cracked steering wheel in very good condition.
I have the over head interior light, glass frosted lens with chrome trim in very good condition.
I do have some soso rear barn doors, only have one set.
I have one good inside rear view mirror. I have one outside mirror, pre-68 but the actual mirror head is not original.
I have at least one original Toshiba headlight, and it works!!
I have at least one set of original seat belts!! :shock:
I have two original generators, at least one of them works.
I have two sets of ALL cooling system parts, on the green 67 that runs it is operational and doesn't leak.
I have all dash stuff, in good condition.
I have one set of original hub covers, for non-free wheeling hubs. These are the hub caps, in perfect un damaged condition, a very rare and hard to find item.
Obviously I have lot's of engine, trans, t-case and axle parts. I got seats and tons of split wheels.
Cheers
Post by RMP&O »
jwgreen wrote:Ian,
I was recently told the 67 window handles will not work on my 69. If this is true then I will not need those. If they will work I will need the trim rings as well. The metal heater intake is what I am needing. I will make a new hose for it.
Ya 66/67 inner door handles are different than 68+. They might work but they don't match or look right for a 68+ Patrol. I got to keep all the trim pieces on the doors for the handles, need badly for some projects I am working on.
I got the heater intake, two to chose from! ;)
Cheers
Has thanked: 15 times
Been thanked: 23 times
Post by weasel451 »
Hey Ian, I'd like to get the little washer that sits on top of the oil filter inside the canister. It's the piece that the spring pushes on. For some reason, I don't have one. Thanks for pulling the regulator...darren
If you have seats...I'd really like to get a passenger side seat. Might be pricey to get it here but let me know, thanks again.
Has thanked: 149 times
Been thanked: 310 times
Post by G60michael »
Front lights for a 66 model the one on the fenders
Been thanked: 48 times
Post by Marshall »
Thanks Ian! :clap:
After seeing what's available and what's not, here's the list of stuff I would like out of available items you listed, (that I can claim). :)
Interior rear view mirror.
Door swing stays/catches (both) - I do have a '67 as well, so these will work.
Glovebox handle.
Nissan hood emblem.
Dash map light assembly and glass cover.
Toshiba headlight (I don't think this is claimed yet)
Overhead interior light.
4 split rims. (once above parts are priced and totaled, maybe I can get a set of these as well, ;) )
Thanks!
Has thanked: 7721 times
Marshall wrote:Thanks for any mirrors you may have!
I figured I may as well do a full sweep on my 67 and get anything you may have. Depending on availability and cost, hopefully I can complete all missing details. Who knows when another donor 67 will come up with a willing mechanic to pull parts. :D
Green/red dash lights. (Pdub got a set, do you have another set?)
Master cylinder reservoir with cap. (ShawnePatrol got the first full mc, I just need reservoir and cap)
Door swing stays/catches (Not sure if these can be removed and reused, as mine are missing)
Rear red little circular reflectors.
All pedal pads: gas, brake, clutch.
Glovebox handle.
Rear metal Nissan Patrol badge.
Nissan hood emblem.
Fuel cap.
Dash light, complete with wiring and switch.
Thanks for your generosity of your time pulling all these parts for us all. :clap:
Here is an eBay listing for the rear metal Patrol badge: http://www.ebay.com/itm/172032667652?_t ... EBIDX%3AIT
Post by Marshall »
Thanks! I actually contacted this guy last night from the suggestion and asked if he had anymore since none were listed - he said he'd list a few for us. Can't wait for it to arrive, sounds like a nice reproduction.
Has thanked: 27 times
Been thanked: 81 times
Post by soft60 »
How were these originally attached?
There is another one up right now - $40 or make an offer.
They were originally screwed on.
Post by soft60 »
River - do you know when the transition from plaque to stickers was made? My 69 does not have screw holes for the plaque, so I assume the switch to sticker was made before 69. Or the holes were filled during the PO restoration.
I much prefer the look of the plaque to the sticker - can you point me to a good photo showing correct plaque location?
Thanks
