Page 4 of 4
Re: Brake Wheel Cylinders
Posted: Tue Aug 13, 2013 5:31 pm
by Bigjoe
I just replaced mine. we are having a bit of trouble with too much play in the instalation and the brake pads or linings keep on coming off track a bit and are grinding aganst the drum. maybe its just me but the brakes seem to float a bit to much. They dont seem to lock into position. 1969 kl60
Posted: Tue Aug 13, 2013 8:53 pm
by bosque
Can you show a pic of the situation?
It could be you have the springs in wrong, the cylinders reversed, the adjustment cam not adjusted or a combo of .....
:shifty: :shifty: :shifty:
Posted: Tue Aug 13, 2013 10:00 pm
The rear shoes will float a bit. The wheel cylinder is held in place with several tension clips, to allow the shoes to float a bit. It shouldn't be sloppy though.
Posted: Sat Dec 18, 2021 10:58 pm
by WaPatrol
Been searching for Brake Wheel Cylinders... seems like these are still our best options?
https://www.ebay.com/itm/331677862533
Posted: Sun Dec 19, 2021 2:31 pm
Yes, these are still the best option.
Posted: Sun Dec 19, 2021 7:22 pm
If you get those, most probably will come with metric threads. Take that into consideration to avoid any damage.
Nissan switched to metric around 1978, so there is good chance of those cylinders being metric as well.
Esteban
Posted: Mon Dec 20, 2021 6:51 am
by r1lark
WaPatrol wrote:Been searching for Brake Wheel Cylinders... seems like these are still our best options?
Also, member 'desertrat' has a company, Patrols North, that has brake wheel cylinders. Here is a link: https://patrolsnorth.com/c/brake
I have not purchased from Patrols North yet, but have corresponded with desertrat about some specific parts.
Posted: Mon Mar 30, 2026 3:17 pm
by MuirBound
Does anyone have a different source for a cylinder set?
It seems the eBay link it no linger valid and cant find these anywhere.
Posted: Tue Mar 31, 2026 10:13 am
RiverPatrol wrote: Sat Mar 28, 2026 7:15 pm This eBay seller has the brake cylinders: https://www.ebay.com/sch/i.html?_dkr=1& ... trol%20g60
