Brake Wheel Cylinders
Original and compatible parts
Been thanked: 4 times
Re: Brake Wheel Cylinders
Post by Bigjoe »
I just replaced mine. we are having a bit of trouble with too much play in the instalation and the brake pads or linings keep on coming off track a bit and are grinding aganst the drum. maybe its just me but the brakes seem to float a bit to much. They dont seem to lock into position. 1969 kl60
Can you show a pic of the situation?
It could be you have the springs in wrong, the cylinders reversed, the adjustment cam not adjusted or a combo of .....
:shifty: :shifty: :shifty:
Has thanked: 7689 times
The rear shoes will float a bit. The wheel cylinder is held in place with several tension clips, to allow the shoes to float a bit. It shouldn't be sloppy though.
Has thanked: 2 times
Been thanked: 15 times
Post by WaPatrol »
Been searching for Brake Wheel Cylinders... seems like these are still our best options?
https://www.ebay.com/itm/331677862533
Yes, these are still the best option.
If you get those, most probably will come with metric threads. Take that into consideration to avoid any damage.
Nissan switched to metric around 1978, so there is good chance of those cylinders being metric as well.
Esteban
Has thanked: 454 times
Been thanked: 789 times
Post by r1lark »
WaPatrol wrote:Been searching for Brake Wheel Cylinders... seems like these are still our best options?
Also, member 'desertrat' has a company, Patrols North, that has brake wheel cylinders. Here is a link: https://patrolsnorth.com/c/brake
I have not purchased from Patrols North yet, but have corresponded with desertrat about some specific parts.
Has thanked: 5 times
Been thanked: 6 times
Post by MuirBound »
Does anyone have a different source for a cylinder set?
It seems the eBay link it no linger valid and cant find these anywhere.
RiverPatrol wrote: Sat Mar 28, 2026 7:15 pm This eBay seller has the brake cylinders: https://www.ebay.com/sch/i.html?_dkr=1& ... trol%20g60
