Rough Running Patrol
Has thanked: 264 times
Been thanked: 776 times
Re: Rough Running Patrol
Post by plateaucal »
Another old school diagnostic test uses a vacuum gauge. For instance: low vacuum may mean worn rings (will show on compression test as well), vacuum leak, wrong valve timing (slipped timing chain), retarded ignition timing, Oscillating vacuum may mean leaky valve or weak springs. Vacuum that drops steadily may be a plugged exhaust.
Just a thought.
Has thanked: 48 times
Been thanked: 146 times
Post by Slackd »
Thanks to all for their input. Much appreciated.
Has thanked: 9 times
Been thanked: 21 times
Post by rrbipu »
Any luck? I can't get mine to stop backfiring un acceleration. I'm working down the list of items. Were did you get your distributor cap and button? I can't find them.
Post by Slackd »
Installed new condenser and points. Seems a little better but still rough at low RPM, runs strong and smooth at higher RPM (>1200). Definitely runs smoother with a little mechanical choke applied.
Slackd wrote:Installed new condenser and points. Seems a little better but still rough at low RPM, runs strong and smooth at higher RPM (>1200). Definitely runs smoother with a little mechanical choke applied.
Your timing is probably a bit retarded. Might be at 0 degrees BTDC. Should be at 10 degrees BTDC.
Post by Slackd »
Thanks Esteban!
