Speedometer Disassembly Guide
Re: Speedometer Disassembly Guide
Duh! This one is green powered and zero emission! It's better for our environment ;-)
Has thanked: 12 times
Been thanked: 36 times
Post by sleepyzzz »
speedo turned out nice.
1967 SPL 1600
2013 Nissan Rogue
2001 Nissan Sentra SE R
Has thanked: 7690 times
Or, you could always just do this. No tampering involved. :D
Did you know that there's a difference in speedo's between right hand drive and left hand drive Patrols? I discovered this while installing it and had to quickly do some modifications! The tabs on the rear housing make all the difference.
RiverPatrol wrote:Or, you could always just do this. No tampering involved. :D
HAH !
Now I'm not the only one around here teasing.... :P
faux40 wrote:Did you know that there's a difference in speedo's between right hand drive and left hand drive Patrols? I discovered this while installing it and had to quickly do some modifications! The tabs on the rear housing make all the difference.
Thanks for pointing that out John. An easy fix, no doubt.
Something else occurred to me. I think the location of the mounting tabs also has to do with the year of the Patrol. Starting in '69 the speedometer was installed to the right of the steering wheel, prior to that it was on the left. When the location changed, so did the position of the mounting tabs. Been there, done that. ;)
RiverPatrol wrote:
That's funny! Did the RHD version swap the speedo to the left in '69?
Has thanked: 529 times
Been thanked: 301 times
Post by 50car »
The earlier speedometers have a different connection for the speedometer cable also. So you need to make sure you have the right type for your year of vehicle.....
Older style is on the left and newer is on right...
Jeff
50Car
The speedo connector change was made in '65.
