Mon Jan 19, 2009 3:06 pm
67l60 wrote:no problem got to like that !!
this makes ians axles really tempting !!
you just swapping out one m/g swivel to 60 shaft right this
should be cake as they used the same u joint
? why not put a locker in the h260 ? i take it you just wanted the lower
gears right any way looks great
now go get the front done up LOL
Yep the plan is to swap out one end of the G60 tailshaft at the uni. Yep I know they run the same uni, so was always the plan.
As I have the Marks 5 speed, which is longer then the 3 speed, I need to work out from my driveshaft stock, what is the best length. I'm thinking the MWB rear shaft with the MQ diff flange part swapped at the uni.
My MQ Diffs are 4.33 and have detroit lockers. The plan with the MQ diffs was lower gearing, but always lockers after the 73 watagans drive. I need lockers to compensate the poor G60 articulation.
Will get the rear tailshaft in before I do the front. Will need to mov the chassis, will be easier if I can drive it
