Front Wheel Cylinder Cups
- Has thanked: 16 times
- Been thanked: 114 times
Re: Front Wheel Cylinder Cups
just to add info to this post, the rear seem to be 1", and the 1992 isuzu 1ton truck has a 1" wheel cylinder. the ACD 18G94 is the kit, also crosses over to Raybestos WK1456. I will know in a few days if it all works or not. got a leaking rear wheel cylinder I need to fix.
I ended up using the raybestos kit to rebuild the leaking rear cylinder. did both sides even though the left was the only one leaking. I need to get it up on the lift soon and check out the front brakes next. may rebuild the cyls on them as well so its all fresh.
