The drive pinion that moves the oil pump at the bottom and the distributor at the top, goes first.
After that you put the base (center in the picture). The top part of the drive pinion will come throughout the hole of the base, and the distributor will fit in the slot of the drive pinion.
Try seating the new distributor over the base. It should go easily. It doesn’t come out at the bottom.
Just hope the single malt I had a few minutes ago is helping me with this explanation.
P-40 distributor adaptation
- Has thanked: 6010 times
Re: P-40 distributor adaptation
Update: Distributor all good, now starter doesn't want to work. New one on the way. Still have to get tdc right, but, soom. Thanks for everybody's help!
