I just bought a Patrol
- Been thanked: 1 time
"Here in the land lead by an Austrian movie star..." Uh, I think he's referring to Schwarzenegger. That would put him roughly in California somewhere.
I was looking at an old Scout today in an old mans field that has the twin stick transfer and has front and rear output shafts on the pass. side. The rear axle was missing but I can't imagine it being center shaft??? Any ideas on the year of this and if it is a 4 spd? Here is something from RMP&O http://rockymountianpatrol.netfirms.com ... ight=#1472 Quote: RMP&O the Warner T98 with 10 spline rear output will accept the Nissan Transfercase input gear without modification, and series LandRover input gear with minor modification. The input shaft splines of some International and Ford T98's are Identical to the Nissan , so you retain the Nissan Bellhousing, fit a simple spacer block cum adaptor plate between bellhousing and gearbox.You need a half inch thick adaptor plate between the T98 and Nissan T/case. You also should machine a new mainshaft nut with an integral bearing diameter on the back of it to fit into a new PTO cover plate machined from an aluminium or steel billet. I will ask my friend on Friday about the recast transfercase. I remember years ago that I calculated I could have got about 2.8:1 with the existing Nissan cast iron T/case by remaking the straight cut low range gears. Anyway just brain storming on a poor mans budget. Marks 5 spd would be the best if you could swing the cash. Keith
