Posts: 43 Joined: Sun May 17, 2015 3:06 am
Has thanked: 3 times
Been thanked: 43 times
Post
by grips » Wed May 27, 2015 8:35 am
RMP&O wrote: Nice set up with the v8 + H55 + split case. How long is the rear driveline!?
Cheers
Rear shaft 530mm (20.86 inches) front shaft 740mm (29.13 inches)
Post
by grips » Wed May 27, 2015 8:43 am
Installed an Aluminium Radiator over the weekend to keep the V8 cool.
When the fan started to cycle at 76°C (which happen to be the thermostat setting) I disconnected it.
Let the temp rose to 90°C and reconnect within minutes it was back on 76.
Post
by grips » Wed May 27, 2015 8:50 am
Safety is a big concern so we constructed a roll cage with bucket seats.
A four point harness to be added for a tight strap in in case of a roll over.
Posts: 414 Joined: Tue Apr 14, 2015 12:12 am
Has thanked: 181 times
Been thanked: 174 times
Post
by RMP&O » Wed May 27, 2015 9:03 am
grips wrote: RMP&O wrote: Nice set up with the v8 + H55 + split case. How long is the rear driveline!?
Cheers
Nice, the H55 - split case combo is pretty compact.
Definitely a good idea on the cage, looks great!
Cheers
Post
by grips » Wed May 27, 2015 11:21 am
RMP&O wrote: grips wrote: RMP&O wrote: Nice set up with the v8 + H55 + split case. How long is the rear driveline!?
Cheers
Cheers
Thanks.
The very reason for the H55 compactness and the overdrive 5th gear.
Also the drive shafts in the same position as on the Patrol.
Post
by grips » Sun Jun 14, 2015 4:01 am
Rust ate away at the 50 year old Patrol. Cut out some rusted panels and replaced them
Posts: 1076 Joined: Wed Dec 05, 2012 4:25 pm
Has thanked: 84 times
Been thanked: 327 times
Post
by miller » Sun Jun 14, 2015 6:30 am
Moving along Grips, well done.
Posts: 7824 Joined: Thu Oct 04, 2012 10:42 am
Has thanked: 7727 times
Been thanked: 2481 times
Post
by RiverPatrol » Sun Jun 14, 2015 9:51 am
Nice fab work.
Posts: 1203 Joined: Fri May 10, 2013 5:35 pm
Has thanked: 652 times
Been thanked: 632 times
Post
by Coyote Patrol » Sun Jun 14, 2015 10:00 am
Looks very nice!
Posts: 1305 Joined: Thu Oct 04, 2012 7:31 am
Has thanked: 104 times
Been thanked: 175 times
Post
by Swerve » Tue Jun 16, 2015 1:47 am
Liking the look of this, well done. Keep moving and more photos !!!!
