Engine oil recommended and oil pressure
Re: Engine oil recommended and oil pressure
Pancho wrote:I am using 20w50 in my Patrol. Just a month ago I realize that when the engine is cold, lets say after the night, it takes like 5 seconds for the pressure needle to start going up? Should I use a lighter oil?
Hi Pancho-
In your climate, I think 10w-40 is the heaviest you should consider, and 10w-30 should work just fine (especially if your engine generates oil pressure above 50psi when it is at operating temperature). :handgestures-thumbup:
10w-30 will get into the bearings and build up pressure much faster than 20w-50 when you first start the cold engine.
