How to remove Steering Wheel
Has thanked: 38 times
Been thanked: 30 times
Re: Removing the steering wheel?
Post by antiquecyles »
Pancho wrote:Here you are a picture of how I do when needed. ;)
Very easy, by the way
Pancho,
That device is obviously a great tool. I rented 2 different pullers from Autozone and they wouldn't work. The splines had some hardened resin/glue all over. It was seized on there so I'm not sure how successful I would have been. I just worked on it, mounted. That's why it came out so crappy :)
I appreciate that pic though. If I absolutely HAVE TO pull the wheel I know what to use now.
Thanks again,
Kris
Has thanked: 181 times
Been thanked: 174 times
Re: How to remove Steering Wheel
Post by RMP&O »
Very nice trick there Pancho! :clap:
I have always used a wood block, BF rubber mallet and a 3lb sledge. Only use the 3lb sledge on the wood block and rubber mallet on the actual steering wheel. It can take a lot of effort if the wheel is seized on but I have never failed to get one off.
Cheers
