Lug Nut size specifications
Been thanked: 17 times
Re: Lug Nut size specifications
Post by MarkL »
Thanks for sending the extra wheel stud, Leslie. Very much appreciate it. Here are the measurements in case anyone has luck finding compatible studs. I emailed the specs to Dorman, but guessing that's a long shot they'll respond/have something.
Mark,
Much appreciated your contribution. Awesome graphics and data.
I will make an important note, since all the nuts and bolts in older Patrols are in Standard (SAE or Imperial measurements) including the lug nuts.
The lug nuts information provided by L60Boerne is correct: Dorman Wheel Nut #611-016, 1/2"-20 Standard - 13/16 In. Hex, 5/8 In. Length
