New garage build
The things we do that keep us from being with our Patrol.
Has thanked: 5859 times
Been thanked: 1549 times
Re: New garage build
It's big! Congratulations!
Has thanked: 84 times
Been thanked: 327 times
Post by miller »
Lookin great mate. Nice video too.
Part 4, just shows the roof structure finished.
http://www.youtube.com/watch?v=DvaT971G ... e=youtu.be
Has thanked: 7328 times
Been thanked: 2400 times
:handgestures-thumbupleft:
Has thanked: 104 times
Been thanked: 175 times
Post by Swerve »
Looking good, another good example of differences in Australia and US. No one here would build that in wood. We would do a steel frame and colourbond (light steel sheets)
No noggins between your studs ? or does the plywood nake them absolete ?
What cladding is going om the ply ?
Should I shut up now :)
Steve
I'm happy to answer....as long as I dont spill coffee on my mac.
Assuming noggins are blocks between studs, we use them to isolate fire and for structural reasons as well but this garage has a different set of minimum requirements than a home. I said minimum because frankly, the owner is just a good dude who worked for a living...retired firecrew....and we're building him as much space as he can afford now so it's bare bones. There will be a minimally finished bathroom but the interior walls will not be covered for a few years and except for bath 0 insulation till next year. The studs are 2 x 6 on a pressure treated sill on the concrete. The outside ply is 1/2", the roof is 5/8", after nailing schedule inspection we will wrap the walls with home wrap and cover the exterior with a concrete/gypsum shiplap style siding. Roof will be composite asphalt tilesheet, no biggie it is what it is. :clap:
You are right Steve, it's different and minimal but his only worry is wind, earthquake, scorpions, rattlesnakes, and black widows out in the dry desert.
Garrit has plans to have a little biz milling diffs or drive shafts or something like that. Heepster guy! :snooty:
We are done with the structure and I believe with this job. The bathroom needs to be built out but the wife would like to see her bathroom in the main house redone before the shop bath gets any attention.....that sounds like a good compromise! ;) ;) ;)
Part 5
http://www.youtube.com/watch?v=vVAEu0RRz0A
Part 6
http://www.youtube.com/watch?v=3yQb0ChG2o4
Post by Swerve »
Good work Dave.
Were you one of the mugs in the shot up the ladder placing the last weather board on ?
Sure is a BIG garage :)
I was going to comment on the size when I saw the video. Great work Dave. What will be the final use of this garage? Is your shop going to be there?
Swerve wrote:Good work Dave.
I am the balder one....and it was 30 x 40 ft. pad and the taller door is 14 ft clear with the actual ceiling taller with the "scissor" trusses used. The last day was 110* in the shade, smokin' hot!
