Leaf Spring Options
- Has thanked: 7721 times
Re: Leaf Spring Options
The width and the pin location are the main differences between the FJ40 and Patrol springs. Possibly the length also.
- Has thanked: 39 times
- Been thanked: 75 times
What did rawml end up doing on his setup? I'm quite sure he had 40 axles under his first project.
Tripper
Tripper
- Has thanked: 54 times
- Been thanked: 17 times
http://thesuspensionking.com/catalog/tables/tables.html
Here's a cool site for referencing springs..
How to Measure a Leaf Spring?
http://thesuspensionking.com/catalog/im ... Spring.pdf
(insert clever saying here)
http://www.stengelbros.com/NissanLeafSprings.htm
another site
http://stengelbros.3dcartstores.com/22-402_p_1832.html
Model Remarks F/R Year Start Year End
Blazer. Jimmy, Suburban Front 1973 1987
Feature 6
Width PL-1 S.E. PL-2 L.E. Eye/Bush Eye/Bush # of Lvs Capacity
2.75 23-1/2 23-1/2 Std/RB-98 Std/1-1/8 3 1400
another site
Feature 6
- Has thanked: 310 times
- Been thanked: 176 times
I will say that I have some sort of fabed spring sets on my '67 frontend. 2 3/4" wide and seem to be appropriate,....a PO thing.
This subject has been kicked around SOOOOOO much and never finalized. 67/60-John W. had gained some knowledge on this but as I recall in the end it did not work or was
delicate some how. He tried....and their is info to start from out there (somewhere
) that you can see.
Maybe not perfect but what about an add a leaf type doohitchy
...in a pinch? This does not necessarily fit, just an example: http://www.ebay.com/itm/1988-1998-GMC-K ... f3&vxp=mtr
There are some specs in mm here I believe (BTW, I have sent these to Alcan for reference)...
I'm just poking and prodding, looking for answers.. with this last lead on the blazer leafs.. I know if I want to get Heavy duty shackles Chevy blazer fronts will maybe be a bolt on.??? Also if you want do an add-a leaf they should work also?? maybe to just boost your pack if the main is still good..
- Has thanked: 23 times
- Been thanked: 65 times
thats just a bolt on carrier leaf kit, it adds a touch more tension back into old leaf packs. on old sagged leaf packs they will give back a little lift but dont really increase the harshness by much, more like bringing them back to what they were like as stock.
cheers
kev
cheers
kev
like a gee six
I dont want to get everyone excite right away but I found this;
Land Cruiser Leaf Springs
Body Style/ F or R Eye Type/ Eye Type No. of
Model Remarks Spring Year Start Year End Spring No Width PL-1 S.E. PL-2 L.E. Bushing S.E. Bushing L.E. Leaves
Land Cruiser
Front 1981 1987 90-112 2-3/4 21-1/2 21-1/2 Std/35 Std/35 5
Land Cruiser
Rear 1981 1987 90-105 2-3/4 21-1/2 21-1/2 Std/35 Std/35 6
Look at the prints above 43" vs 41.3" that's awfully close. and lots of fj60's getting parted.. At least for the fronts, I'm still working on the rear.. those prints are really hard to read although I appreciate them they confuse me..
Land Cruiser
Land Cruiser
Hey Bob,
I just went out a nd measured.....the front looks like a bingo....seriously! I measured about 43-43 1/2 on my 62 and checked the 65 too. The fron and rear portions are equal (21 1/2 + 21 1/2). 2 3/4" width!!!!!!
WTH? I think you found it for the front springs!
