ditributor gear
Locked
ditributor gear
Post by npca-millerpatrol »
Has anyone been able to remove the gear from one of the water proof distributors? I can't find a pin or any other means of removing it . I'm trying to change over to an HEI system. Thanks Ed
ditributor gear
Post by npca-67l60 »
did you look into a dizzy from a 280 z  i hear it works out great and dosnt look funny when mounted  just thought id ask John
ditributor gear
Post by npca-kl604x4sss »
I have looked in the message board for any reference of the distro but not enough detail on how to make it work.What are you using?Abraham_________________________________________________________________Don’t just search. Find. Check out the new MSN Search! http://search.msn.click-url.com/go/onm0 ... direct/01/
ditributor gear
I have seen pictures of  the z distributor on the net.I don't know how that conversion would work,the shaft looks too short.I heard that the z conversion does not allow for proper oil cooling .I'm using a chevy distributor from a 250 straight 6. The guy I talked to said that all you have to do is shorten the shaft,grind a new tip and make a new gear. I would rather use my old gear but I don't know how it comes off without damaging it or the shaft. Thanks Ed
ditributor gear
MY DIST DOES NOT HAVE A GEAR JUST A LITTLE TIT SO I  CUT THE GEAR OFF MADE  UP A MOUNT AND I HAD TO GRIND THE SHAFT TO ACCEPT  FEMALE TIT  IVE DONE THIS TO A LATE MODEL 4.3 DIST BUTT DIDNT LIKE HOW IT TURNED OUT  JUST LOOKED FUNNY WERE AS THE Z DIST BOLTS RIGHT UP AND THERE ARE SEVERAL PEOPLE USEING AND I HADNT HEARD THAT COMPLAINT SO I WILL HAVE TO DO MORE RESEARCH  BEFORE GOING THIS WAY
ditributor gear
Post by npca-hublocker1 »
try your local nissan forklift company for major engine parts like thedistibitor they still use the type p40 engine in there largerforklifts....hublocker 1
ditributor gear
FORGET!!! THAT  GO TO .NISSAN 4WHELLERS.COM IN PATROL FORUM ,GREAT HOW TO PLUS PICS THIS IS WHAT IVE BEEN WORKING ON FOR SEVRAL DAYS WITH ONE HAND LITERALLY  I HAD SURGERY ON MY LEFT HAND 8 DAYS AGO SO I STILL CANT USE IT VERY WELL . BUTT CHECK IT  OUT IT IS VERY EASY I GOT ALL MY PARTS FOR 20 DOLLARS OUT OF A JUNK YARD BEST PART WAS, IT ALL LOOKED NEW  JUST MAKE SURE ITS OFF A CARBURATED MODEL WITH A 5SPEED PLAN TO INSTALL THIS WEEKED AND CHECK IT OUT
ditributor gear
I checked out the website!!It's awesome, it looks like it's minimal work to do the convertion. I will give it a try as well and post my DIY article some time in the future.Unless the author of that DIY does not mind positing his article here instead. It will help a lot.
ditributor gear
just give him the credit  you being a datsun  fan  you probably have this part laying around somewere  i used a non waterproof dist didnt want to destroy my waterproof one  just incase i made a boo boo
Locked
